Humbug
| posted on 19/4/05 at 11:12 AM |
Fixing instruments in c/f dash
I have a c/f dash from Stuart Taylor. It seems quite thin and I am wondering whether I should back it with something, e.g. a thin piece of plywood
before fixing the instruments.
locoboy
| posted on 19/4/05 at 11:26 AM |
Definately.
Is it radiused o the lower edge to pass SVA?
I believe the SVA testers give it a bit of a yank too
Locoboy
NS Dev
| posted on 19/4/05 at 11:51 AM |
It has a full radius on the bottom edge doesn't it??
Surely when it's bolten in place it's pretty strong? Try this first before adding wood!! Rather negates the lightness advantages of CF!!
adampage
posted on 19/4/05 at 11:52 AM |
I have one...
I have a stuart taylor with the CF dash, which yes, is radiused for sva, and yes, does wobble a bit.
The instruments are just on the CF on mine, and it all seems to work fine, but I don't think it would be a problem if you added a thin sheet of
plywood, or even just a broom handle in the big groove under the dash where it is radiused (if you see what I mean) to stiffen it a bit.
HTH,
Adam
Humbug
| posted on 19/4/05 at 04:04 PM |
Thanks for the various replies. The dash has got the radiused bottom edge. I must admit I got it more for looks than light weight, so I will
look at adding some stiffening.
