mark chandler
| posted on 18/2/07 at 09:57 PM |
Steering cowl
Nearly done now, body built, wiring in etc, only nasty that I have left is the steering cowl.
How have you made up the gap between the scuttle and the sierra cowl ?
Cheers Mark
graememk
| posted on 18/2/07 at 10:08 PM |
get a longer one
RazMan
If you use an adjustable column cowl then it's nicely taken care of
[Edited on 18-2-07 by RazMan]
Raz
PaulBuz
| posted on 18/2/07 at 10:09 PM |
I found I had the same problem. Made one from some ally
And before someone points it out, yes, it was a lot of hassle. But then nobody told me there was a longer one available!!
[Edited on 18/2/07 by PaulBuz]
Paul
tegwin
| posted on 18/2/07 at 11:02 PM |
Where does the longer one come from?
DarrenW
| posted on 19/2/07 at 09:10 AM |
From a Sierra fitted with an adjustable steering column i believe. My donor was H reg DOHC (GLS i think) Sierra and had the adjutable column. Cant
remember what the cowel looked like though as i chucked it. i didnt use any of the std switch gera so was able to get the ally lock barrel housing
modified and polished. MOMO steering boss also came with a nice round cover (not too long though).
darrens
| posted on 20/2/07 at 07:27 PM |
Razman
Where did you get your steering wheel and boss from. Looks pretty.
RazMan
| posted on 21/2/07 at 12:09 AM |
Both are Momo jobbies that I found on eBay - I painted the boss (along with the rest of the switch gear & covers.
Raz
