LBMEFM
| posted on 1/9/07 at 08:05 AM |
Temp Dashboard
Hi
I have a carbon fibre effect dashboard which I do not want to use until after the SVA. Therefore, as a tempory measure would it be acceptable (for
SVA) to build a dash from 6mm ply covered with foam backed vinyl and a lower trim (taken from the the door shut of the Sierra) along the bottom to
give it a radius. The switches and dials will be placed behind the steering wheel.
Barry
shortie
| posted on 1/9/07 at 08:18 AM |
Yep, exactly what I did.
Rich.
Humbug
| posted on 1/9/07 at 08:30 AM |
As long as it meets SVA requirements you can do what you like afterwards!
repper
| posted on 1/9/07 at 10:04 AM |
do you have to have a soft dash for the SVA then as i was going to have a carbon afec dash in my car will this not pass then ???
| posted on 1/9/07 at 10:58 AM |
It doesn't have to be padded but the edge / radius requirements are more stringent it its solid.
