mikeb
| posted on 2/7/08 at 12:58 PM |
TVR Gauges
Has anyone tried fitting a set of old TVR griffith gauges, i have seen a set fairly cheap around £70. Would look a bit more modern than a mgb set but
not cost the earth?
M
| posted on 2/7/08 at 01:05 PM |
looks loke electronic speedo so should be fairly easy to interface that.
I donlt think there are many modern TVRs with 4 cylinder engine so you need to beware the rev counter may not be compatible.
stevebubs
| posted on 2/7/08 at 02:03 PM |
red line on that tacho is a bit low for a zetec...
