So i'm only 1 month into selling my car and feel withdrawal symptoms with regard to my vehicle. I bought a bike to get me through this year but
feel next year I may look at buying one and creating my type of reverse trike. Just pricing up an R1 with V5, maybe a trackbike, Something to get it
up and running and through its test. I quite fancy putting a V twin engine in though, and also its going to need a reverse of some sort.
I think in comparison to the MNR I built I should be able to put this together in maybe 3 months, maybe less depending on what I have on.
Has anyone bought one yet?
Any pics at all?
They now have a road legal demo so I may have to take a trip to Notts to test it out.
Nick
No, but I wouldn't mind a go in one. I suspect that if I did, I'd be buying one soon after.
Not a big fan (but love it's seat design!)...
Just out of interest... MSVA doesn't concern itself with mudguards - would the rear hugger in the photo below satisfy MOT regs?
Similarly - would that placement of the reg plate and rear-lights be acceptable?
[img][/img]
Image deleted by owner
£104
And the daft question of the year.
If you get one through MSVA, what would happen if you added another wheel if you do not change chassis?
But, if you built a 7 and you can mod it in a way that you can built it as a trike and then convert to 4 wheels you would end up paying a lot less instead of IVAing it
You couldn't add a wheel to that design without 'radically altering the chassis", so an IVA would be required.
That said... even if the chassis design was such that a fourth wheel could be added without modification, then I think the change to 4-wheels would be
enough in itself to require an IVA.
I could be wrong... I frequently am!
I do like the look of those but cant help wondering what the traction will be like? I imagine it'd be faily rapid but not as quick as two driven
wheels.
That said it'll still be quicker than my 1.6 pinto!!
Regards
Rich
The only thing that you will need to consider is to add the extra brackets for the suspension, differential and wishbones and probably find a way to
have a bolt on cage to strengthen the differential area.
[Edited on 13/7/10 by l0rd]
a trike can only be msva'd as a trike if the wheel plan is symetrical. This is noted on the V5, changeing the wheel plan to '2 axle' would be a major mod in the eyes of the dvla i reckon.
Is it just me or does £4k seem a lot for what's in the kit?
Yep...
What about using the solid axle from a quad bike??
These fit onto fairly standard looking swingarms.
Hey presto!! Four wheels, loads more traction and completely unpredictable handling!!
Geoff
Originally posted by RichardK
I do like the look of those but cant help wondering what the traction will be like? I imagine it'd be faily rapid but not as quick as two driven wheels.
Wouldn't matter... you've added a wheel, so the 'category' of the vehicle has changed and it will need the appropriate inspection.
What about if you take a video and pictures showing the before and after the change showing that the chassis hasn't been moded.
The donor bike is quicker than a 2 wheel drive car and it only has 1 wheel.
IMO it looks unfinished at the rear, like a lot of the mev stuff its the same but different to their other stuff. The cost of the kit almost
outweighs any IVA saving(for what you get).
A way of involving the donor parts in the design more would make it look 100% better at the rear.
