Hi All,
I am planning on converting my fiat twin cam powered seven to EDIS4.............I am somewhat familiar with what's required but just
need some clarity on a few things:
1. I am planning on running on EDIS4 only (No megasquirt etc).....does anyone know why this cant be?
2. I read somewhere that the EDIS4 module works out the ignition advance by registering the trigger wheel speed, therefore we have a basic advance
curve?
thanks people.
I believe that EDIS will give a flat 10 deg advance unless connected to some sort of ECU
As said, EDIS only will give you fixed timing, you need something to advance/retard in response to engine speed / load.
There is a simple module on some fiestas and escorts, which will provide a 2 dimensional ingnition system, I can't remember which cars had them,
Big_Wasa will be along soon, he's used this setup, might be worth a u2u to him.
Thanks R1_pete. that makes sense.
