Type9 clutch cable lengths
John Bonnett - 26/3/23 at 12:40 PM
The clutch cable I'm using has an eye for a clevis pin and the outer is about 920m long. I can find no record amongst my purchase invoices of the cable but I would like to know what vehicle it's from so that I can buy a spare.
I would be grateful if anyone could post a list of type9 clutch cable lengths please but only those with an eye at one end..
Thank you
John
big_wasa - 26/3/23 at 03:43 PM
I trawled eBay, Burton power ect and just compared escorts, capris, cortina’s, granadas and so on.
John Bonnett - 26/3/23 at 04:30 PM
I've just done the same thing but cannot find the lengths on the Ebay ads. Burton list and extra long cable with a length and hat might do. I just need to ask them what length the outer is.
Many thanks for your reply.
John
John Bonnett - 27/3/23 at 08:10 AM
Just to complete the story, I've just called Burton and the extra long cable has an inner length of 1230mm and the outer 950mm which is pretty close to what I have fitted so I've ordered a spare. Job jobbed!
tims31 - 28/3/23 at 07:39 AM
I think the code quoted in replacement part listing relates to the cable length or at lest did in my case. I fitted a QH replacement part which was quoted as QCC 1148 and is 1148mm in length but also another companies code was BC1148 and these are Capris Mk II/III cables
John Bonnett - 28/3/23 at 08:30 AM
Good information. Thank you. I needed the longest cable I can get to give a smooth run and the one I've ordered from Burton is very similar to the one already fitted which is fine.
nick205 - 28/3/23 at 01:52 PM
Seem to recall using a Capri clutch cable on my MK Indy (Pinto with Type 9 an MK supplied pedals). I think I needed the length to get a smooth enough curve betweeb bulkhead and gearbox.
John Bonnett - 28/3/23 at 03:30 PM
Yes that's the problem I have Nick but there is also the exhaust manifold to contend with which is on the driver's side on the Sigma.
johnemms - 28/3/23 at 07:03 PM
Ford Cortina Left Hand Drive Cable ... Maybe?
John Bonnett - 28/3/23 at 07:11 PM
I don't know if it's for a lhd car but this is the one I have and it is fine
https://www.burtonpower.com/clutch-cable-ford-cortina-mk3-mk4-1-6-2-0-sohc-pinto-to-8-79-qcc1010.html
nick205 - 29/3/23 at 09:31 AM
Hi John,
I had the same issue in my MK iNdy (Pinto engine, so exhaust on the RH (Drivers) side). I had to secure the clutch cable clear of exhaust manifold with a rubber lined metal P clip. Worked OK and it didn't suffer. I did cover the tubular exhaust manifold with heat wrap as well, which probably helped avoid too much heat.
[Edited on 29/3/23 by nick205]
John Bonnett - 29/3/23 at 12:00 PM
Hi John,
Hi Nick,
You've made a really neat job of insulating the manifold and that's something I shall definitely need to do both for the clutch cable and the steering column U/J which are both very close to the manifold.
