twybrow
| posted on 9/9/11 at 04:07 PM |
Help installing a Power Commander on ZX12
Should there be a separate earth feed in the PC loom somewhere, or does it connect to earth via the large loom connection blocks? I ask, as I bought a
PC3 (serial connection) off ebay (here we go...) and have set about installing it, but when I found some additional instructions online, they show the
fitting of a separate earth, but this unit doesn't seem to have one. I have completely unwound the loom tape, and taken the back off the PC3
itself, but I can find no evidence of a separate wire... I am getting a green light on the PC3 when I power it up, but my computer isn't
recognising it as being there - hence I got worried about the earthing! Ok, enough from me... Anyone able to offer any experience with these things?!
Ta.
Johneturbo
| posted on 9/9/11 at 05:24 PM |
The two that i've fitted, one for R1 and the zx14 both have had a seperate earth cable
Moorron
| posted on 9/9/11 at 05:38 PM |
my usb version has a power and earth not on plugs but i dont know about the pc3 version. When plugged up does the lights follow the throttle when its
moved? I would say its more the pc connection if you cant find a wire thats been cut off and a driver will need to be installed aswell as the
commander software before the pc can be plugged in.
