TimC
| posted on 30/11/05 at 09:13 PM |
Wheel Offset for GTS Panther?
Greetings...
Does anyone know the ideal offset for a Panther with Cortina front end?
14" dia if that helps.
Ta
flak monkey
| posted on 30/11/05 at 09:15 PM |
Nope....but I will be using Capri Laser wheels...lol
I think the cortina offset was ET19. But I stand to be corrected!
Sera
http://www.motosera.com
TimC
| posted on 30/11/05 at 09:21 PM |
When I say Cortina front end, I mean uprights - like yours..
TimC
| posted on 1/12/05 at 11:51 AM |
Anybody know?
Help...
Gav
| posted on 1/12/05 at 01:17 PM |
I would imagine it will be the same for any other car that uses the cortina uprights?
flak monkey
| posted on 1/12/05 at 01:31 PM |
Are you worried about matching the track front and rear? And worried that putting the wrong offset on the front will make it wider or narrower at the
fron than the back?
If so, then the difference will be 38mm max. I cant remember what the standard offset was on sierras (ET38 i think). If it was, then the max
difference you will get is 19 (each side)x2=38mm. I wouldnt worry about it.
If you are worried about the extra load on the bearings. I wouldnt worry either, the Panther is a circa 550kg car, so much less than the sierra or
cortina (then you knew that anyway!).
Like I said I am putting Capri wheels on mine all round, and dont forsee any problems.
I would likewise not see any problems fitting Sierra offset wheels all round either.
Sera
Triton
| posted on 3/12/05 at 09:11 AM |
Might be dreaming again but wheel offset for Sierra based Locost is ET38....Escort based Locost is ET19.
Most make their 'bones on the Sierra based kits the right width up front to match the rear track so no need for different offsets front to rear.
www.tritonraceseats.com
www.hairyhedgehog.com
