Made for the ZX9 C1/C2 engine, not sure if it will fit the later E model
It is approx 50mm in height
Includes a baffle plate and shortened pick up pipe. This was fitted, but never used on the road as I sold my unfinished project.
The sump has been tapped for a oil temp sensor
Please email me with any questions on anuppmail-locost@yahoo.co.uk
£215 sent special delivery or collected from NW London
ZX9 Sump
[Edited on 18/8/09 by anup]
Can confirm it will fit an E, they are identical.
did you mean oil temperature sender btw ?
would be a bit of a worry if the sump oil was under pressure
Al.
The sump has been tapped for a oil pressure sensor
I'll upload pictures shortly.
ZX9 Sump
would be a bit of a worry if the sump oil was under pressure![]()
Al.
lol yes! Oil temp is what I meant!!
Thanks for the confirmation
