FS: Facet Posi-flow fuel pump up to 180hp and regulator
cloudy - 17/9/09 at 05:48 PM
As I've moved to injection, for sale is a facet posi-flow fuel pump (60107) rated for up to 180hp 4-7psi and a Sytec pro-flow 1-5psi adjustable regulator. This should be a very flexible combination - covering almost all carb pressure requirements. Supplied with 8mm tails and and pump has it's inline filter. I've added some hot melt glue to the cable exits as there is no strain relief as supplied...
Pump: £25 delivered
Regulator £20 delivered
£40 for the pair delivered
[Edited on 17/9/09 by cloudy]
cloudy - 21/9/09 at 10:27 AM
Bump, no interest?
dan8400 - 27/1/10 at 08:51 AM
Hi, have you still got the regulator?
I'll give you £20 for it mate
Dan
