Hi all, i am selling my treadmill it is 1 year old, it is in exellent condition,it folds upright so you can store it away when not in use, i am
looking for £300.ono. The spec is as follows. Horizon Fitness Quantum3 HRC CS Treadmill
Specifications:
8 Programmes: Multi-level including; manual, cross country, hill run, after burner, heart rate, race, and 2 user programmes.
Console: 4 window red LED with Dot-matrix profile and direct speed keys.
Feedback: Time, speed, heart rate, distance, elevation, calories.
Heart Rate Feedback: Hand grip pulse and Polar chip receiver.
Speed/ Elevation: 0.5 - 11mph/ 0-12% incline.
Running Area: 140cm x 45cm.
Cushioning: Variable Elastomer Cushioning.
Max User Weight: 300lbs/ 21 stone/ 134kg.
Motor: 2hp.
Frame: Silver colour heavy gauge steel.
Dimensions Open: L185 x W84 x H134 (cm).
Dimensions Folded: L90 x W84 x H177 (cm).
Weight: 98kg.
Running Belt: 2 ply no curl belt.
Running Deck: 18mm pre-waxed.
Rollers: 1.75" dynamically balanced/ 80% tapered.Image deleted by owner
treadmill pic 2Image deleted by owner
treadmill pic 3Image deleted by owner
treadmill pic 4Image deleted by owner
