Its windy out and my shed is too full, so here is my shed clearout.
I didn't want to put all the pictures in but they are in this linked version. LINK WITH
PICTURES
ZX10r 04/05 throttle bodies. No fuel rail. I bought these because they are massive. The secondaries have been removed. These can't be
respaced like the GSXR k1,k2,k3 ones. Althought he central spacing could probably be changed. THese are marked T009 K436. Spacing is 78-87-78mm,
54mm o.d., 43.5mm i.d. on engine side. o.d. 51mm i.d. 46mm on airbox side. TPS works. MAP sensor I am not as confident about. £50 posted.
zx10r TBIs
zx10r TBIs other side
Adapters for the above TBI's to engine
TBI adapters zx10r
GSXR600 fuel rail, no injectors. Spaced at 80-80-80mm. Actually I have 2 of these. £5 each, £8 the pair including postage.
GSXR600 fuel rail
the other one looks the same!
SOLD to avagolene: Adjustable fuel pressure regulator for carbs, with brand-new filter (another change of plans!!). £15 inc postage
Fuel pressure regulator with filter
second photo of fuel regulator
New fuel filter in box. Not appropriate for fuel injection. 8mm tails. £5 posted
Fuel filter
Horn, this came as pair, but in the interests of lightweight I only used one. This is the lower tone one. £5 inc postage
horn-photohorn-photo2
A grab bag of Sierra stalks and such. Horn contacter, ignition switch (SOLD to Davg), indicator stalk(SOLD to Davg). Free (well postage costs) maybe
£1.50 each.
odds and sods
Starter switch, standard stuff, I didn't use it in the end, rubber end isn't perfect. £3 posted
starter button
Starter relay, gsxr600 I think, with a main fuse. £3 posted
starter relay
Sold to Charlie_ZetecHigh level brake light. £4 posted
high level brake light
Steering arm ONLY ONE. Capri, RS2000. Ford part. Both pictures of the same one. £13 posted
steering arm
steering arm
SOLD to flibble:Brake T-pieces, new from CBS (when I thought I had a problem). £6 posted each. or £10 the pair.
T-pieces
BMW mini side repeaters. MK1. I ended up using Alfa Brera ones. £6 posted (the pair). THese include the bulbs and some cable adapters.
Indicators
Amp meter. New in box. £5 posted
Indicators
Still available: Wilwood master cylinder kit. No hose (although it isn't IVA approved anyway). This is a 1inch master cylinder part
number 260-3378.
This has been kicking around my shed for a while, In box. £8 posted (heavy) collect if you want for £4.
Wilwood brake master
Rev counter. Suzuki rev counter. Red lined at something mad. 15k. Standard connections on rear..256910.
Rev counter
zx9 silencer "titanium". Some road rash on this. Quite light. Free if you can collect, otherwise £10.
Zx9 silencer Titanium
Sierra steering wheel. Horn might not work so well, but otherwise ideal for IVA. Free if you can collect.
Sierra rear calipers. Seem to work, but probably best used to check dimension or for part-ex on reconed items. Heavy so postage is a lot.
Collect and they are yours for £10. Not really worth posting.
Rear calipers Sierra
I am based near Oxford. So come on over if you want any of this stuff for massive discounts. My goal really is to empty the shed rather than make
any money.
Matt
Link with pictures
[Edited on 14/11/09 by matt_gsxr]
first dibs on the willwood 1" master cylinder kit.
Would be good for my bike clutch!
Ash
U2u'd also
I'll yake the CBS tee peices please
Bought a similar exhaust yesterday for more than that
damn!
Edit: Is that a road legal can?
[Edited on 14/11/09 by flibble]
yes the exhaust is standard kwak marked with E1 which I think means its road legal. Its got a dent or two on it, so probably not that great.
Just want to clear the space.
Matt, dibbles on the ind & ign switch. u2u sent cheers D
U2U sent for pressure regulator.
U2U re. high level brake light....
U2U sent re the side repeaters and silencer.
I can't seem to edit the original post now.
Shed clearout
I didn't want to put all the pictures in but they are in this linked version. LINK WITH PICTURES
ZX10r 04/05 throttle bodies. No fuel rail. I bought these because they are massive. The secondaries have been removed. These can't be respaced
like the GSXR k1,k2,k3 ones. Althought he central spacing could probably be changed. THese are marked T009 K436. Spacing is 78-87-78mm, 54mm o.d.,
zx10r TBIs
TBI adapters zx10r
GSXR600 fuel rail
SOLD to avagolene pending collection : Adjustable fuel pressure regulator for carbs, with brand-new filter (another change of plans!!). £15 inc
postage
Fuel filter
SOLD to Tatey Horn, this came as pair, but in the interests of lightweight I only used one. This is the lower tone one. £5 inc postage
ALL SOLD to DaveGA grab bag of Sierra stalks and such. Horn contacter, ignition switch (SOLD to Davg), indicator stalk(SOLD to Davg). Free
(well postage costs) maybe £1.50 each.
odds and sods
starter button
starter relay
steering arm
steering arm
T-pieces
SOLD to TateyBMW mini side repeaters. MK1. I ended up using Alfa Brera ones. £6 posted (the pair). THese include the bulbs and some cable
adapters.
Indicators
Indicators
Still available: Wilwood master cylinder kit. No hose (although it isn't IVA approved anyway). This is a 1inch master cylinder part number
260-3378.
Rev counter
SOLD to Tatey zx9 silencer "titanium". Some road rash on this. Quite light. Free if you can collect, otherwise £10.
I am based near Oxford. So come on over if you want any of this stuff for massive discounts. My goal really is to empty the shed rather than make any
money.
I'll probably e-bay anything left.
Matt
Bits were sent out by Royal Mail today.
Any problems then let me know,
Matt
