As above Sierra XR4 x 4
£150
+ postage
This is to finance new diff on TVR (partially)
In Devon although sometimes trvel as far North as Bristol !
Am I right in saying this is a 7.5 inch diff?
Do you know the ratio?
Thanks,
Craig.
I thought the XR4*4 diff was 7" with a 3.62 (LSD) or 3.64 (LSD) ratio?
But I could be wrong - it has been known.
[Edited on 8/1/10 by Charlie_Zetec]
I believe it is 7" and 3.62
If from an XR4x4 then it will be a 7" 3.62 LSD, (if it's the original diff). Cheers Ray
Unless its 4x4 DOHC 2.0L then its a 7" 3.9 LSD.
