Bought Sep 2008 and used for 10 trackdays in my Striker. Ratios are;
2.66
1.75
1.26
1.00
0.86
Top of the range helical gearbox that cost £1400 + VAT
Fantastic upgrade for £700
Very tough box with revised oiling and well spaced gear ratios. The E8 has the stronger synchros as well. My E7 has been used regularly with 200 lbs ft through it on my supercharged Striker.
Very good but what is a E8 gear box ?
is it a type 9
follow the link and all will be revealed
http://www.bghgeartech.co.uk/html/5_speed.html
its a BGH modified type 9, its the strongest one they do - 280bhp / 240 ft.lb
(as in the link above)
I've got one too, but I can't say much about it because I've not used it yet
btw - it might be worth adding if its a long or short input shaft one
(I'd guess its a short one)
[Edited on 11/1/10 by mcerd1]
Sorry, its a Ford Type 9 short input shaft 5 speed gearbox built by BGH geartech.
I've got one too, but I can't say much about it because I've not used it yet![]()
btw - it might be worth adding if its a long or short input shaft one(I'd guess its a short one)
lol petrol will be fifty quid a litre
U2U Sent
You may never find out at the rate your buildinglol petrol will be fifty quid a litre
NOW SOLD
