Due to fitting a new tank I have my old one up for sale.
The tank is mild steel and is baffled. The inlet is 45mm OD and the outlet is 10mm OD. You may notice the outlet is at the top of the front panel of
the tank - there is a pickup inside the tank connected to this.
The top the the tank is angled so that it is flat when fitted in the angled rear section of the book chassis.
The sender is from OBP if you want to check the OHMS. It also comes with 2 straps (2mm thick and padded).
Collection only im afriad from my folks house in bromsgrove, or my work in Wolverhampton.
Measurements are
height of back 24 cms
height of front 20 cms
width 20 cms
length 72 cms
£40 collected
[Edited on 17/1/10 by prawnabie]
