In a bid to clear some much needed space in my garage I thought I would see if anyone on here wants any non-locost car parts before they go on ebay.
They are new and unused unless identified otherwise. All prices incl postage/courier and are negotiable!
BMW E30 parts (bought for a '90 325 Touring)
Hand brake cables (pair) £20
Rear beam poly bushes (fast road spec) £60
Rear wishbone pivot poly bushes £80
Front brake pads £20
Rear brake pads £20
Rear disks £40
Front strut top mounts £80
Rear damper top mounts £15
Front and rear standard spec dampers £120
Rear antiroll bar droplinks £15
Secondhand Distributor cap and leads (less than 6 months use - bl**dy £75 new aftermarket!) £35
Secondhand parts for complete manual gearbox conversion (box, prop, flywheel and [useable but used] clutch , pedal box, master/slave cylinders,
hydraulic line, mount, new release bearing and new spigot bearing) £220
Pug 306 (1997 turbo diesel)
Front wishbone front bushes and rear bush units £15
Citroen 2cv
Transverse exhaust collector unit £50
Audi 100 (1988 Avant)
Front and rear brake pads £30
Jaguar XJ6 (1995 onwards)
VW Golf mk2 16v
Water pump £25
and finally parts that might have use in a locost!
Sierra front hub carrier top alloy mushrooms £35
Secondhand Rover v8 auto bellhousing (bought for a t5 box requiring adapter plate) £60
Secondhand Sierra v6 LSD - working condition and quiet but has light corrosion on some of the crownwheel teeth where it has sat in the garage for too
long £125
