i have for sale
1; honda s2000 clocks (2003 car 25 k) these are currently mounted in an alloy plate with seperate fog light,fan over ride, and hazard switches. these
can be seen in my blog underneath
2;AEM 1012 ECU bought from honda s2000 specialist garage R (this is a programmable unit which is a direct replacement for oem unit. uses same plugs
and connectors from honda loom)
3;modifry yellow jacket speedo caliberator
4;modifry coolant temp harness for AEM ecu (gives wider temp range on honda clocks)
5;AEM wideband lambda kit with digital guage/controller, and bosch sensor!
basically if you have the complete honda loom this will plug in and run. you can then strip out what you dont need as the unit does not need a/c, air
pump,central locking etc
u2u me if interested in the complete package or i may split as the digital clocks can be used in other installations and the wideband can also!
