hi i bought this diff as a 3.62 off a fellow member but have now found out it is a 3.92 so between the to of us we are going to try and sort it out
so
for sale a 3.92 lsd diff out of a cossy the fellow i bought it of took the cover of and removed the 2
circlips that held the shafts on if you are going to use it it would need to be checked and readjusted for clearence if yo want you can look up the
add
cosworthspeed10 and lsd
i am looking back what i payed what was £100 regards jonny hope this makes some sence
[Edited on 27/3/11 by joni]
Just removing the two circlips will not affect the clearances, it just allows you to take the bolt on shafts out. HTH Ray
