Have changed my mind on what I'm doing with the Tiger again and have decided to go for 45's instead of injection (anyone have any for
sale?)
Below are some pictures and this is what is included:
- Bogg Bros manifold to take bike throttle bodies and be fitted to a Zetec
- ZXR 45mm throttle bodies
- Throttle position sensor
- Throttle linkage
- Fuel rail
- Injectors
- Fuel pressure regulator
- Air filters
- All the stuff to make them fit together
Looking for around £370. Any question please U2U and don't hesitate to ask.
Now for the pictures:
If you ever decide to split this i'd be very interested in the manifold!!
You don't happen to have an ECU going as well would you?
I'll see if I can sell it all together and would prefer to sell it this way. As for the ECU already gone sorry.
I have twin weber 45s on my pinto and will be going with the setup you have there when I change to my blacktop so they will be up for grabs maybe do a deal? I obviously have a pinto manifold not zetec.
have a set of 40's on a zetec manifold with all linkages if any good
Hmm having had webers I couldnt wait to get rid and go injection.
Mine where the proper zetec spec 152g five progresion hole dcoe 45's.
Fighting the urge........
Just out of interest, what else (excluding Omex/MS) would i need to get these running on my carbed Zetec?
High pressure fuel pump (maybe 2 but can use a normal low pressure fuel pump for the fuel to go back to the tank), wiring loom for the ecu, air and water temp sensors, cat and you may also need a lambda sensor.
Price drop to £350.
Will let these go for £300 now.
U2U sent
