A Few Parts for sale
bag of 1/2" p clips £3 +p+p
bags of 10 x M10 Nyloc nuts £1 + pp each
sheet of plastic grill mesh Approx 3ft x 2ft £4 +pp
Dremel multitool No bits, just tool and spanner and box £10 + pp
Exhaust 1 - has has some cutting and welding at outlet, but solid and surely of use to someone £20 +pp
Exhaust 2 = has been blowing from front of box hence paste but sure someone could weld it up, again has had some cut and shut at outlet but may be of
Old radiator - outlet broken and sealed shut from overflow. hence £7 +pp
Camping set used once £7 +pp
Cooling ducting tube - £3 +pp
Exhaust shield - few scuffs and dings but generally good £15 +pp
wing piping - 2 x lengths 1x 3ft 1 x 4ft £5 +pp for the pair
edge strip approx 5ft - £6 +pp
gear gaitor surround £3 +pp
cooling hose - £4 +pp
MR2 alternator - £10 +pp
XFLOW alternator - £10 +pp
EMPTY GAS bottles any use to anyopne?
RED Cooling hose 2 lenghts £10 the pair 30mm dia
Dibs On the following - Can I collect?
Grill Mesh
Dremel
Edge Strip
Gear Gator Surround
Cooling Hose (black Rubber)
Ta
First dibs on
Coolant red hoses and wing piping
Rob
1st dibs on cooking set delivered
Grill Mesh
Dremel
Edge Strip
Gear Gator Surround
Ta
Originally posted by Rob E
First dibs on
Rob
Can i have exhaust shield please.
i'll have the alternator, how much for postage?
cheers,
andy
thats the xflow alternator btw
U2U sent about MR2 alternator.
Wyn
2nd dibs on dremel, mine has just stopped working
