I have available a working STACK 8100 dash display, c/w wiring loom and 4 Programme select SWITCHES recently removed from my kit car.
The dash rpm rev range is high and is more suitable for a bike engine application hence reason for sale (although STACK can re-calibrate the
display).
Dash features include:
Oil Pressure (with programmable alarm)
Oil Temp
Water Temp
Fuel Pressure
Battery Volts
Wheel Speed
G sensor for acceleration recording;
Lap Timer (lap timing beacon included);
Stopwatch clock
Back light
Alarm Tell-tale
Alarm buzzer (can be pre-set)
Alarm light
Can add additional rev shift light
There may be more ....
No sensors included apart from the Lap Timing Beacon.
Was fitted to an R1 Jedi hillclimb car before my application and includes data from this set-up. I only used the basic parameters of Rev, Oil temp,
Oil press, Water temp, Fuel Pressure and wheel speed for my own application.
Have a look at this model on the STACK website to be double sure.
Postage is Royal Mail 1st Class Special Delivery & Insured - £7.50 GBP UK - but will post international (contact me for details of postage
costs)
Happy to answer any questions - viewing welcome, call / Text me for more details on 07866 465125
By the way, even though rev needle in the Pic shows 2k rpm, when it is powered up the needle re-sets to ZERO in case anyone is wondering.
Will post a pic of the loom and 4 Programme Select switches shortly.
Looking for £425 ovno
Droool, i wish i had £400 spare for this right now! Good luck with the sale, seems a good price
hi is there no chance of the sensors being available?
Hi,
My replacement dash is a Stack as well and needs the sensor. You can get them from various suppliers other than the Genuine brand, if you PM I can let
you know where you can get them.
SOLD - thanks
