Fireblade Engine package
hiflow - 5/10/11 at 05:55 PM
Fireblade Engine Package
SC28 893cc Fireblade N spec.
Still sitting in my Indy can be tested if required. I,ve done around 20 miless on this engine, as car is not tested.
Just fitted new EBC uprated clutch plates and uprated clutch springs
Pipercross filter assembly
AB Motorsport Dyno Jetted carbs, running around 120-125bhp , very quick car on 3.92 diff. (Got video of car running)
Comes complete with Loom/ecu/stater/Alt /leads / EXHAUST MANIFOLD + system /fuel pump.
Just had oil & filter change + new plugs & leads,rocker cover gasket
Complete lighting loom+fuse box , made for MK indy + dash assembly (dash covered in black leather)
Dash consists of Stack 0-7-14 revcounter, Koso Digi fuel gauge & speedo, push start button, oil pressure & water temp gauge (new black face units), indicator/neutral/main beam indicators/ fog light switch/brake level warning indicator
Fireblade engine craddle, drive flange and gearlinkage rods.
I will also throw in a 3.92 diff . I,m runnning 195/45/50 tyres and speeds are as follows ,
12200rpm =1st 45mph, 2nd 63mph, 3rd 80mph, 4th 90mph, 5th 101 mph , 6th 108mph (worked out from calc sheets NOT TESTED LOL)
Got pics of insise the engine , totally mint condition
cracking little engine and goes VERY well, Ideal for BEC starter kit for someone or buggy
£1600.00 ono
can ship on pallet to the UK
