Picked these up a few months back on a whim, sadly I realised after they are for the 2.0 silvertop, and not the blacktop. I was hoping they might fit
but this is unlikely and I need to release some cash, so they need to go.
http://www.webcon.co.uk/Alpha%202005%20Product%20range%20Flyer.pdf
This is the 'Gold' kit, so comes with everything you need, not just the bodies and manifold but all injectors, loom, ecu, gaskets etc etc
too.
Model K99011 - Ford Zetec 2.0l, 16v (Evo 2 (ie silvertop))
BRAND NEW NEVER FITTED!
The current version of these (K40011) are £2000.
£1600ono posted.
[Edited on 18/11/11 by loggyboy]
I thought the manifolds where the same spacing on silvertop and blacktops. I have a blacktop exhaust manifold on my silvertop
I believe its the sensors and loom that are different.
The black top sensors can be fitted to the silvertop, its a case of swapping the thermostat housing at most.
I agree with wasa.
The only proper difference,is the thermostat housing
and the oil pressure sender.
Just swap them for silvertop items.
Thanks, I might do that if they dont sell, however with a new boiler on the cards I still need some funds!
