Hello chaps, this is my first for sale posts on here so just to let you know I've been selling on ebay for a long time. My user id on there is
ssts32 with a total of 550 feedbacks.... so I would like to think that i'm a geniune seller, and good guy. if i have any problems with your
transactions ie non courier collections etc, i will let you know straight away.
1. Rally designs 140lb springs, 6" long for 1.9 dampers. almost brand new, 10 pounds plus postage...
2. Vodou vr5 front lower a arms, brand new. (built to vodou book specs) 50 pounds the pair, plus postage..
3. Vodou vr5 upper rear adjusters, one has a much longer m20 welded on then the other. (the mounting points for the mx5 rear uprights are off by 3/4mm
on these if you can machine/drill them out and then reweld another shim on these will be perfect.) 15 pounds the pair, plus postage...
4. Sierra lower steering coloum, already modded with an additional cv joint. 15 pounds plus postage..
5. Haynes rollover bar, with harness bar (not welded together) the harness bar has got captive threaded bar seam welded inside already. I will get
more specs on the harness bar tomorrow morning. 45 pounds, plus postage...
If you have any questions just ask away... also you can collect, i live just of the m40 jcn 8a wheatley oxfordshire... you may also get a cuppa
foc!!
[Edited on 29/2/12 by stuart collins]
I forgot to say pictures will be uploaded tomorrow morning.
Hi,
I'm interested in 4 + 5 subject to pics and postage cost.
Somebody else has got dibbs on 5, as for 4 I'll find out tomorrow. how would you like it tobe posted? (courier, first class etc...)
Stuart
Stuart
http://i239.photobucket.com/albums/ff196/stuartc-1/kit%20parts%20for%20sale/20120229_124142.jpg
http://i239.photobucket.com/albums/ff196/stuartc-1/kit%20parts%20for%20sale/20120228_132832.jpg
http://i239.photobucket.com/albums/ff196/stuartc-1/kit%20parts%20for%20sale/20120229_124107.jpg
http://i239.photobucket.com/albums/ff196/stuartc-1/kit%20parts%20for%20sale/20120228_132825.jpg
A pair of eunos (mx5) mk1 import seats, these are the ones that you can fit speakers into the headrests. they need a hover (which i will do) no wear
on the bolsters, complete with runners. appox 440mm wide.
70 pounds, plus postage.
http://i239.photobucket.com/albums/ff196/stuartc-1/2012-01-01095820.jpg
Sierra lower colum sold...
I've also got a sierra master cyclinder for sale complete with level cap for the iva. it will need a clean out, but ive had it pumping.
17.50 plus postage....
