I have a 2.0 silver top zetec, shortened sump and a letter from Ford stating that it's pre-emissions.
(no alternator) (£150?)
a decent clean and working Type 9 and steel bell housing (£100?)
Starter motor (free if you buy the engine and box)
Single throttle body inlet manifold (with tps) (£30?)
Megasquirt (not even sure what version it is, ....
but fully working and mapped to the above engine)
I have also got a set of respaced throttle bodies, (with tps, fuel rail & injectors) mated to ST170 plastic inlet manifold (£200?)
these items are up for sale, however I am not sure of the value,... the prices are guesses,..
If they are of interest, please U2U me,
pictures to follow at the weekend
thanks
u2u re engine and box
How much for the megasquirt
can you pm me more info on the throttle bodies i would like more info
Also interested in the throttle bodies with intake if you can give some more info!
Thank you for all your patience, the pictures in the following post might help answer some questions, there are other pics in my archive, each in a
folder with a handy name to help identify the right one,...
so,... from the top,. all items are in Leicester and were taken off my Fury, or were going to go on my Fury and are not now.
Postage is extra, and the engine/gearbox is collection only, the discs would be expensive to post too,...
(no alternator) (£150) Has Megasquirt trigger wheel.
clutch is correct for the Type 9 below,..some wiring loom also available
a decent clean and working Type 9 and steel bell housing (£100) no clutch release arm as yet, but I might find one,..
(Flick waiting to hear from you, if you are still interested)
Single throttle body inlet manifold (with tps) (£50)
Fuel rail, regulator, and injectors all in working order - tape measure not included
Air filter, used, but seems clean enough £10
Megasquirt version 2.2, in a very nice aluminium case. £100, inc a spare plug
EDIS unit £25
I have also got a set of respaced throttle bodies, (with tps, fuel rail & injectors) mated to ST170 plastic inlet manifold £200
Includes ST170 injectors, and some loom, also second set of injectors and respaced fuel rail in the ITB's believed to be from a Busa. Was for an
experiment with 2 stage injection, but have run out of time,... as ever. There is a throttle cable cam and the tps is working.
Set of original sierra calipers and standard ventilated discs. Pads included, almost no wear on the discs, and new pads last year £50
standard discs/calipers
Please U2U me, I am away for a few days and will get back to everyone on my return.
Collection preferred, postage / shipping extra. I wont ship overseas, and I have yet to discover the joys of paypal,...
thanks for looking
[Edited on 18/3/12 by HowardB]
U2U sent about the Megasquirt.
Cheers, Chris.
u2u sent for itb's
Rear calipers or just fronts ??
u2u re inlet manifold
