1. refurbished garrett T3 watercooled turbo,with new bearings,thrust,collar,oil seals and coolant fittings. (from s2 rs)
2. S2 RS turbo exhaust manifold.
3. Braided oil feed kit with fittings to connect to the oil gallery.
4. Brand new exhaust manifold adapter plate with a full set of bolts.
5. Brand new 1.5mm stainless decompression plate.
6. A tube of non setting sealant to seal the decomp plate.
7. A new 20 psi boost gauge with fitting kit.
8. 1 meter of new 5mm blue silicone boost hose.
9. used rover inlet manifold and injectors.
10. new rover inlet adaptor plate with bolt kit.
11. used 130 zetec cams.
had these sat in the garage doing nothing. was goint to sell last year, but was tempted to do another seven rep.Its never going to happen if im honest
with myself, so now for sale again. photos over the weekend if i get chance. collection from nottm or bedford to brighton railway stations (via st
pancras, london bridge). however i can post if needed.
wanted £350 for everything, but will split if any intrest.
How much for No. 1 & 11?
How much for 5,6+7 please?
