I'm in the process of swapping from a 1.8 silvertop to a 2.0 blacktop zetec in my Mojo, after a cam tensioner failure resulted in 16 bent
valves!
I therefore have the following for sale, all taken from a 130ps Zetec from an Escort. PM if you are interested.
1.8 waterpump, was working fine, pump turns right way with a simple belt route so ideal for converting 1.8 & 2.0 Mondeo engines for use in a kit.
£10 + post - SOLD
Cam cover sprayed silver. 'Zetec 16v' on cover. Looks much nicer than standard, one or 2 minor marks, not invested much elbow grease in
cleaning it up for the pics! £15 + post:
Other bits may be available, let me know what you want, e.g. have no plans for cylinder head / 130 spec cams, but bear in mind that the engine has 16
bent valves so no idea what is serviceable (but those items would be free to a good home, buyer to collect and remove!)
Based in Warwick.
[Edited on 30/4/12 by nre]
Do you have the rubbed pulley for the water pump?
Also are you re-using the alternator and brackets?
I do, can bundle with pump or sell on its own.
...but no don't have alt or brackets :-)
You have u2u ref pump pulley. Thanks. Joe.
Can I have the water pump please if it is still available.
Len.
Yes pump still available, I'll U2U postage cost and paypal details!
Thanks...
Pic of cam cover added...
