few bits for sale, pick up Stonleigh Sunday
Bizarro - 29/4/12 at 05:19 PM
Ive had a bit of a clear up and have a few bits that may be of use to someone + get me some cash to buy more stuff at Stoneleigh!!!
I dont get chance to go to the post office during the week but I am planning on going to Stoneleigh on Sunday so all items collection Stoneleigh, thanks.
Zetec throttle bodies 1 X plastic new, 1 X cast used in good condition. £15 for both
11" Mountney steering wheel, used. £13
Rotary light switch/horn push, new. £5
Same as this: http://www.cbsonline.co.uk/product/Large_Rotary_Headlamp_And_Horn_Switch_HL-HSW
SW mechanical speedo and tacho. Both look to be unused, speedo has 25 miles on the odometer. £60
Type 9 gearbox mount, used. £4
Type 9 speedo cable, used. £4
Handbrake cable, not sure what for, doesnt fit Ford calipers, new. £10
Brake disks, dont know what they are for, the box has part #14115NCP. 230mm dia, 50mm off set. New. £15
Sierra Cosworth rear brake disks. 270mm. Thes are too big for my MK, I am using Ford rear calipers and MK supplied caliper brackets, they would fit with different brackets. New. £20
Any questions please ask, cheers.
TimC - 29/4/12 at 05:41 PM
First dibs on rotary switch please.
theduck - 29/4/12 at 05:44 PM
U2u regarding speedo and tacho
Bizarro - 29/4/12 at 06:08 PM
The speedo and tacho are 4"
Speedo is mechanical, tacho electonic.
The fitting on the speedo is a screw type:
Bizarro - 29/4/12 at 06:10 PM
OK, Ill u2u later in the week with contact number and what time Ill be at show. Cheers
