I have for sale a 2.0l black top zetec from a low mileage car in perfect condition, it comes with a set of ABP strengthened rod bolts,new clutch,
release bearing, thrust bearing,and flywheel to convert it to RWD, CVH sump, mini alternator.
I also have a set of ZX9 carbs with TPS plus inlet manifold plate to make a manifold.
A megajolt ECU(new) edis, triggerwheel(although this isn't needed with the cvh flywheel) etc.
Basically everything you need to convert it to RWD and run it on bike carbs. I was told the engine was perfect and low mileage when I bought it, but ,
i have never had it running.
It's located in cheshire and I'm looking for £450.
