Fireblade engine kit + lighting loom + gauges
hiflow - 19/5/12 at 11:16 AM
This engine is currently fitted in my Lotus Seven type kitcar. The engine runs sweet as a nut and it is producing around 125bhp @ 11500pm.
Honda SC28 Fireblade engine, 893cc with a power band like a sledge hammer. This engine came out of the Urban Tiger 1993 spec Honda Fireblade.
The engine has a set of Dyno jetted carbs by Andy Baker (AB Performance)
The engine has had EBC cltuch plates and uprated clutch springs
New Spark Plugs
Pipercross Air filter
New rectifier
I am also selling the exhaust manifold & exhaust system ,(purchase new from MK)
Fireblade engine craddle
Fireblade loom / CDi & / fuel pump.
I WILL ALSO SELL THE MY CAR LIGHTING LOOM and dash assembly. THIS means you can put this entre package into your KITCAR. The dash consists of a Stack rev counter/ smiths water temp gauge / oil pressure gauge / Push buttom start/ High beam indicator / direction indicator light/ Low brake fuild warning light. KOSO digitail speedo + pickup. Fog lamp switch & neutral indicator The dash panel is cover in black leatherette
The stack rev counter is a St400 model , scale is 0-7000 - 14000 rpm. It has a built in data logger. The Stack does needs to be recalibrated to operate with the blade coil packs. The rev conter reads twice engine speed.
You will also get drive sprocket / prop assembly & serria diff.
The diff is a 3.92 diff
I will also throw in the gear linkage assembly
Cooling water pipework.
All you need todo as far as wiring goes is to wire the indicator & lights into switch. If you cannot do this, i will do this for you , at an extra charge .
Please remember you are getting a fully running engine + exhaust + fuel system + coolant system + wiring loom + car lighting loom+ dash assembly.
The engine is still in the car and be heard running.
Looking for £1400.00
I have pics of engine + dash , but dont know how to put on here.
