Hi all some parts for sale starting to clear garage out,
Sabelt harness 2" 4 point in good condition but no bolts,
£80 posted
As seen in this pic on my mnr seats
vortx seats
Dax rear tub holes cut for lights
£50 collection only due to size
Boot box in yellow to match £20'
Mk radiator
£25 posted
mk radiator
Intercom system
£60 posted main 12v one all working,
intercom system
[Edited on 8/8/12 by INDY BIRD]
Which way do the lap straps adjust? Where abouts in essex are you?
Hi harness aree pull down,
I'm about 1 hr 10 mins from Stevenage, I'm near haverhill suffolk, place called Finchingfield,
They are ok in a seven where they came from,
Thanks, I've got my iva on monday so I'm not sure I will need them until after that. Ill let you know. cheers
I'll have the rad please.
U2u on its way.....
Jossey u2u details etc thanks
Intercom sold,
Bump on items still for sale, do you still want the rad as had no u2u ?
bump
bump
intercom now sold though
any interest?
Any pics of boot box??
I'll get some tommo for you
bugger would have had the intercom.
too slow!
Interested in the harnesses where is the lap adjustment on these is it near the anchor points or near the centre buckle
I have some trs ones and the adjuster is on the anchor points which is covered by the seats in my car so makes it a little awkward
Sorry harnesses now sold last night picked up,
Sorry about slow post on this
Regards
boot box pic added
Could you post the boot box???
Prob cold post not sure how it would fare to post?
It would be down to you if you want that,
Or unless you know a courier etc to arrange collection ?
Let me know as I'm not sure on cost to post this item, due to size,
I'll have a look on net now and let you know.
Every time I find something to buy its miles away
Sean, how much does the boot box weigh?
If its less than 15kg, use "my hermes" to move it -'they come and pick it up from your door it's all a little too easy - but they
don't do anything > 15kg (you might also have to check the volumetric size too)
BUMP
dax body work still for sale boot box and rear tub,
£60 for the pair if wanted
thanks
sean
