LSD
aerodynamix - 30/9/12 at 08:47 AM
Ford LSD complete in casing , tag on casing indicates 3.92 . Top mounting is two bolts so I am thinking this will be a 7.5" diff although stand to be corrected .
The chap I bought it off stripped the car for spares and used the gearbox and engine , as far as he was aware it was in good running order when car was broken although I cannot confirm this personally , I was told it came from a Sierra xr4x4 DOHC .
Yours for the sum of £150.00 , I can arrange delivery but would have to check cost due to weight , I would imagine to standard uk adresses it would be £20.00 or less .
u2u me or ring 07971 264550 or email : julianeisel at aol.com
Cheers Julian
please note this is a personal sale as is not related to my business
[Edited on 30/9/12 by aerodynamix]
snapper - 30/9/12 at 08:55 AM
Stand up and I will correct
It'll be a 7" 3.9 LSD diff or it should be if it came from a 4x4 2.0L DOHC
aerodynamix - 30/9/12 at 08:59 AM
Yes I make it a 7.5" but I was told it came from a xr4x4 2.0 DOHC , so I too make it from information I have looked up to be a 7.5" and not the 7" that you would assume to be fitted to that type of car all I can suppose is that the guy gave me wrong information and was more likely to be a granada or scorpio that it came from .
Chippy - 30/9/12 at 09:32 AM
Well it's a fairly easy check, just measure across the top fixings, if 7" thats what it will measure, equally if 7.5" thats what it will be. HTH Ray
loggyboy - 30/9/12 at 11:49 AM
also easy visually too, if the top bolt goes in to a hole and doest reapear till it comes out the other side its a 7.5, if you can see the bolt between each side then its a 7".
(7 inch on left)
aerodynamix - 30/9/12 at 01:52 PM
Thanks for all the replies , I can now confirm as already mentioned this is definately the 7.5" diff with LSD , it has the two bolts on the top mounting , is of 3.92 type and has bolt on CV's and definately measure 7.5" .
This also shouldn't have come from the vehicle mentioned who I bought it off , this came with other items I needed so is surplus to requirements , now we know exactly what we are talking about any takers ?
aerodynamix - 2/10/12 at 07:32 PM
Now On Ebay : Sierra / Granada 7.5' LSD Differential Westfield Kitcar Pilgrim Locost Caterham | eBay
aerodynamix - 9/10/12 at 06:29 PM
SORRY SOLD
