Honda 919 engine & exhaust Package
Boltsy - 9/10/12 at 10:08 PM
You are looking at a complete engine & exhaust package for a Westfield Megablade or 7 esque type of kit car. The following is included within the price:~
1 x Blueprinted Honda Fireblade 919 engine producing 151.3 Bhp @ 10206 rpm & 79.1 lbft @ 9312 rpm
Throtttle bodies
ECU
Engine Loom
Coils & Leads
Bespoke hand built exhaust system from manifold to silencer
The above are currently installed in my Westfield SEIW Wide Track and buyers are welcome to come and see / listen to the engine before it is removed from the car. The engine has done approx 6000 mile and is perfect as is the gearbox. The oil has been regularly changed after each outing and it has been maintained regardless of cost. The reason for the sale is that i have to change the engine package to the next seasons RGB spec's (1000rr) as i am going racing! These engines are bullet proof and is a seriously fast when installed into a 7 type kit car and not for the feint hearted. I have rolling road print outs which will go with the units.
If you would like to know more or would like to come and see it, call Kevin on 07906 358217 to arrange.
I am looking for £1500 for the lot and if you are looking to install this reliable engine into your car, it's got to be a no brainer. You get everything you will need. You can even come and help remove it if you want to so you get an idea of where it all needs to go when you put it back in!
I also have a second engine for sale by seperate negotiation. (£500)
Cheers for now.........
MK9R - 10/10/12 at 07:06 AM
oohh another new comer for next season
Is this Bens old westy you are converting??????
If you need any help, just ask.
Boltsy - 10/10/12 at 07:24 PM
Hi Austen,
Yup...you are right in 1...Bens old westy is coming back next season. Andy is sourcing the bits for me and will probably be helping out like he does!! I'll be at Mallory on Sunday so might introduce myself around a bit.
Thanks for the offer of help. Might take you up on it if i get stuck.
