DTA S40 FULL INJECTION ECU Brand New
snakebelly - 4/11/12 at 10:34 AM
With the change in plans from Zetec to T4 we no longer need our DTA S40 FULL INJECTION ECU, its brand new and never been fitted cost £535 lwhen purchased 18 months ago and can come as a bare ECU or with a complete Zetec Loom and Sensors.
ECU Only with programming lead
£485 Delivered
ECU With brand new Zetec Loom, Oil Pressure Senders X1, Air Temp Sensors X 1, Water Temp Sender X1, Oil temp Sender X1, Jenvey supplied TPS X1, 1X Crank Position Sensor All senders apart from the TPS and Crank Sensor are brand new, the TPS only has about 5 hours run time on it. those of you who have been this route will know that the sensors alone add up quickly. Temps are around £30 each, oil pressure over £60 etc etc etc
£585
[Edited on 4/11/12 by snakebelly]
snakebelly - 8/1/13 at 03:27 PM
sold
