Hi All
Few bits and bobs for sale. I inherited all these bits plus a lot more when I purchased a race car back in September, but have just really got round
to working out what’s what.
All items are in USED condition except where stated NEW. All electrical items have been tested with a 12V battery and seem to be fine. Items that
can’t be tested using a 12V source have been tested for circuit continuity.
**SOLD** Item 1: 4 x GAZ Shocks, single adjustable damper setting (dimensions as per photo) £70 plus P&P bit gruby but should do the job.
Item 2: 4 x 8” springs (for above shocks) 2 x 300lbs 2 x 325lbs good clean condition. £50 plus P&P The photo says Protech, but i cannot be sure
that they are.
Item 3: Facet Fuel Pump. Looks battered but seems to be working fine. £20 plus P&P
**SOLD** Item 4: Sytec Motosport Fuel Filter (NEW) £5 plus P&P
Item5: Davis Craig Water Electric Water Pump (not sure of the flow rate, assume it’s the 80L per min one) £80 P&P FREE
**SOLD** Item 6: Wilwood Master Cylinder .750 (Seems to be okay, not 100% sure) £5 plus P&P
**SOLD** Item 7: Wilwood Master Cylinder .750 (Works fine) £10 plus P&P
**SOLD** Item 8: Wilwood Master Cylinder .750 (NEW in package) £20 plus P&P
Item 9: VDO 10Bar Fuel Pressure Sensor (has continuity on circuit and I assume its what I think it is) £5 plus P&P
**SOLD** Item 10: Kill Switch with 2 keys (NEW, still in packet although looks a little tatty) £4 plus P&P
Item 11: Slave Cylinder with Clevis. £22 plus P&P
If interested in any of it, please U2U me.
Ed
[Edited on 19/11/12 by edsco]
I'll have the battery Kill switch please. If you send me your email address i can do you a paypal payment if thats ok?
Leon
You have u2u re new Wilwood MC
cheers Jon
You have u2u for Filter, thx
I'll have the fuel filter if the above doesn't
Can i have the shocks please u2u on its way
PMd re Two Wilwood master cylinders...
Ed, read your u2u then promptly deleted it !!
Send details again please and I will action this evening.
Ta
Wombat
As per request....resent.
You have u2u on the springs
U2U sent for electric water pump.
Item 5 and item 11 now SOLD
Item 3 SOLD
Items 2 and 9 STILL available
[Edited on 24/11/12 by edsco]
