For Sale 1x top mounted pedalbox removed from Westfield 7se , believed to be mk1 escort , comes with master cylinder and sleeve required to mount
clutch cable .
Master cylinder is single circuit and is free and not seized , reservoir is nice and clean too , cylinder is 0.625 , I believe that you can fit a dual
circuit cylinder such as a Cortina item to this .... needless to say I don't have one of these ....
I also have the brackets that were welded to the chassis if required ( I have cut them off reasonably neatly )
I'll update when I've put some pictures up .
£20.00 posted to standard uk adresses by courier ( it is heavy post will cost £10.00)
I do have the glassfibre cover too , this can be included for £10.00 , rear return has been trimmed but just fits against scuttle without return on .
u2u sent
Still available , pictures can be emailed if required .
U2U sent
And replied to
Sold
