Hi,
2.0 Pinto 205 block, new rings, bearings, cam shaft, vernier pulley, lighterned flywheel not just skimed, short sump and pick up profesionally
done,new spray bar and seal etc, new clutch, rocker cover filler located to the back, home made manifold with zxr1100 carbs with foam air filters, i
will include the fuel pump.
Also type 9 gear box with remote gear shifter , (i think its from westfield, but not a 100%)
Other bits to follow
£350 cash on collection
Would you sell the remote separately?
Not as yet i would rather let them go together or at least the engine and the full gear box seperate.
why are they always so far away!!!
what would you want for the engine on its own??
[Edited on 5/3/13 by unclechief]
Want to sell the box and carbs separate mate?
Pm's replied
Is engine ready to fit and run? Or does it need some work/ setting up first? Any idea of the power?
Hi,
You have a personal message.
Phil.
PM sent back
Engine and gear box now sold
Ive got a recently rebuilt standard pinto in case anyone is still looking. Its only done 2,000 miles since an expensive rebuild and I'm only selling it to fund building another engine.
