Hi a pair of 45mm aluminium wheel spacers with studs and wheel nuts. £60.
Pics are in photo archive in for sale folder. Thanks
Jesus, I’ve just had some 40mm ones made, whats the pcd and inner centre bore (half sheft) and outer bore (wheel). I will see if I can justify a spare set if 108 pcd and bore sizes are ok.
Sorry forgot to put it in the description. The pcd is 4x108 and both the inner and outer bore are 63mm. Thanks
u2u sent
Are there's still for sale ?
Hi sorry these are sold. Also not sure how much they cost to make i bought them off someone a while back. Thanks
If it helps I paid £42 inc delivery for 2 x 150mm diameter by 50mm wide bits of aluminium (Aluminium Warehouse) then about £26 for 8 x 65mm studs/nuts and delivery. Then £40 for machining. Cheers.
Should be pretty easy to make if you have access to a lathe? Might be tricky to get the holes in the right places but doable.
