Set of 4 compomotive ms rims ford pcd
2 6x13 et32
2 7x13 et-7
£130 Collection from Eastbourne or arrange own courier.
[IMG]http://i147.photobucket.com/albums/r284/CRAIGRR/P1030642Small.jpg[/IMG
[Edited on 14/4/13 by CRAIGR]
BTTT and £125
Can bring to Stoneleigh if necessary
Would have snapped these up if they were all the et32, don't think -7 will fit under Indy arches?
Get yourself some wider arches for all that busa power and stick the comps on . You know it makes sense .![]()
You not at stoneleigh then ??
I am but will be in my kit so getting them back could be problematic! I'm going to speak to someone tomorrow to enquiry about the cost of the wide arches and how running that et will change the scrub radius and I shall let you know :-)
Okey dokey.
if it helps, am coming in tintop and am only in rotherham so not far from you. I can fetch back home for you
