Change of direction forces sale, advertised on behalf of a friend:
GBS Race zero rolling chassis-
New GBS Wide body race zero chassis powdercoated
with bias pedal kit, full rollcage, lowered floor
All ali fitted apart from one side of gearbox tunnel, bonnet ready for fitting catches
Black bodywork with front wing upgrade CSR style (rear wings fitted), black dash already predrilled ready to bolt up
GAZ coilovers fitted
Custom made fuel Ali tank foam filled with Suburu impreza high pressure pump (in tank),
New premier wiring systems loom fitted in place ready to connect up, lights, engine etc column stalks connected
Megasquirt with edis and loom
Set of 6 black with white needles/lettering, tacho upto 8k, speedo upto 140mph
New brake lines fitted
New fuel lines for injection fitted
Sierra steering column and lower extension fitted with upgraded bearing mount.
new steering rack fitted
polo radiator (new)
sierra running gear has been refurbished or replaced, diff, shafts, brakes in place, front uprights in place with new calipers and vented disc(discs
fitted)
upgraded front upper adjustable wishbones ( also have originals) fitted
Tsw alloys (need new tyres)
Vauxhall redtop complete will need to be checked will come with distributor pump, flywheel and any other associated parts will be included.
Type 9 gear box with correct ali bellhousing for redtop
Modified manta sump (has been welded)
Engine mounts including rubber mounts
Suzuki 38mm throttle bodies re-spaced to fit original modified manifold with joints and jubliee clips
Donor V5
Bascially everything is virtually there and the hard work has been done. The above is likley to be worth around £7k all in.
Being realistic and wishing to make space quickly it's advertised at £3,950 ono
Please call 07582 205237
I am having problems loading Jpeg pictures, if you send you direct email address I can send pictures direct
This can easily be on the road for £4,5/5k
Pair of lightweight black fisher fury style fibreglass seats available at extra cost £130
Aero wind deflector available at extra cost £50
[Edited on 17/4/13 by striker1660]
hi u2u sent ref v5
can you send pic of seats
chaddy44@hotmail.co.uk
