Weber Alpha Silver Carb Kit for 2.0 Zetec 45 DCOE
ragindave - 16/4/13 at 11:22 PM
Kit: 9902
This is the complete kit and was purchased new and installed on an engine in a car and stood for some while no fuel has ever passed through the carbs but the alloy/fittings have some discoloration
http://www.burtonpower.com/weber-alpha-carburettor-ignition-kit-zetec-20-45-dcoe-5-98-webk99002.html
These kits combine the legendary Weber DCOE carburettor and the hi-tech Alpha 3D mapped ignition system. This proven combination releases the performance potential of a wide variety of production engines, and covers both the fuelling and ignition requirements, in a fully integrated package. Supplied as complete bolt-on packages, these kits are calibrated and mapped for standard specification engines. For other states of tune, the ignition may require recalibration. Kit includes: 2 x Weber DCOE side draught carburettors, Alpha 3D ignition system, throttle linkage, inlet manifold, air filters, wiring harness, throttle position sensor and fitting instructions. Typical power is 165bhp.
£850.00
[Edited on 17/4/13 by ragindave]
