LT100 lap timer for sale - in good working condition, although rear battery cover needs taping shut as the clip broke some time ago. Triggered by the
beacons installed at the circuit, also seperate beacons are available if you want to have your own.
These are around £120 new, so looking for £60 delivered (or £55 collected from near Huddersfield).
Also, have a pair of Pheonix/Striker clubman mk4 sidepods up for grabs - need a bit of work to make them look good again, but would be fairly easy to
make these highly presentable again (Drivers side is a bit damaged at the corner join so needs a bit of glassfibre to join the two bits back up again,
the other just cosmetically needs tidying). Lightweight, now at £20 as I need the space.
