1 x open Sierra diff, 3.62:1 ratio, push-in type driveshafts - £20.
1 x pair Sierra push-in type driveshafts with hubs still attached - £20.
1 x pair backplates & drums complete with all springs & locating arms and even brake shoes! £ 20.
1 x pair Sierra front hubs with 240mm vented discs - £20.
1 x pair Sierra front hubs with 260mm vented discs - £20.
PM me or text Mark on 07783 644840.
There's pics in this library which you
should have access to, please let me know if not.
They are as you can see 'as they came off' i.e. surface rust 'n all but came off working cars (one of which I drove home then scrapped
on my drive
I'll take a pair of hubs/discs please if postage is an option ?
The smaller discs please.
It will be but they're heavy batsrads, I'd imagine postage'll be a tad pricey.
I probably won't be able to weigh them until Saturday due to time evaporating on me (as usual), will that be OK?
Hello,
I'm interested in the Sierra Differential and the matching driveshafts, they would need to be posted as I live miles away in Chandlers Ford,
Hampshire
Let me know
I can do that David, bear in mind that the cost may be prohibitively high. I'll do my best to get these items weighed and let you know how much.
Postage should not need to be that high if you use parcel2go or interparcel.com I sent a set of Granada shafts and hubs for about £15 with TNT although you have to wait for them to collect.
Originally posted by Minicooper
Hello,
I'm interested in the Sierra Differential and the matching driveshafts, they would need to be posted as I live miles away in Chandlers Ford, Hampshire
Let me know
£14.85 with TNT.
In case you are able to find a cheaper quote they weighed in at 32kg for the pair (allowing 0.5kg for packaging) and measured a rough 400mm x 300mm x 300mm stacked and allowing for packing.
Hello,
Let me know
All postage quotes from Parcel2Go.com.
Diff - 22.5 kg with packaging, measures 350mm x 550mm x 300mm, £7.75 + V.A.T. with Yodel 48.
Driveshafts - 20.5kg with packaging. 900mm x 250mm x 200mm. £7.75 + V.A.T. with Yodel 48.
Backplates and drums - 17.5kg with packaging. 300mm x 300mm x 300mm. £7.75 + V.A.T. with Yodel 48.
Total postage comes to £27.90 including V.A.T.
Please let me know if you still want them.
£14.85 with TNT.
Did you price Parcel2Go.com. ?
Looking at the other postages prices it looks like it may be cheaper ?
Bank transfer ok ?
Rob
u2u re hubs
All now sold excepting the rear hubs/backplates/drums.
£20 anyone?
I've still got the rear hub/backplate assemblies, brake drums and brake parts if anyone's interested, £20?
