Got some spares from a pinto engine.
mechanical fuel pump £12 posted
oe ford thermostat housing £12 posted
rocker cover with baffle plate £15 posted
clutch ,plenty of life left in it ,no release bearing. £20 posted
tensioner pulley £10 posted
pics can be got if you need them for anything.
Hi
If its in good condition I will take the thermostat housing please.
Ian
ill get pics of all the parts tomoz please bear with me. your name is on it mate.
Great thanks.
forgot about engine mounts as well.
20 posted the pair.
Hi
Does the thermostat housing have the small take off for the 10mm overflow hose. That's the one I need as my take off has broken off and is
araldited on.
I can't see one in the picture but it might be on the other side?
Ian
hi dude.
if you look at the housing the small take off is pointing at just past 6 oclock
it has the small one and the obvious large one. nothing else
Hi thanks didn't see that ! Sorry.
I'll double check mine tomorrow morning first thing and all should be fine.
Hi again,
I've checked and all good to go. Let me know how you want the money, PayPal, cheque etc and email your details.
Ian
