Luego Viento For Sale
The luego Viento is a larger version of the caterham/westfield type of car and is a factory built chassis. The car has a larger engine bay and more
cabin space to fit people 6ft+ and of the larger build (Car is currently setup for me at 5ft10 but the seat can be bolted into another place to suit
you)
The car has passed its SVA check and is fully road legal. The date of first registration is 09 04 2009
TAX and MOT until 2014
Includes full build paperwork and manuals
Chassis and bodywork
Chassis is factory made buy Luego, powder coated black
Its double wishbone suspension all round with polybushes, and i had the crush tubes plated so they wont rust
The bodywork was supplied buy Luego as well
The bodywork is in a bright red colour with alloy side panels
Engine and Transmition
~400bhp sr20det engine from an s14 200sx
Garrett GT2871r turbo
750cc Nismo injectors
Z32 air flow meter
Metal head gasket
ACL bearings
Uprated engine mounts, they are nice and stiff but remove the vibrations
Tubular exhaust manifold
Uprated wastegate actuator
3" straight through exhaust
Aluminium intercooler
Apexi air filter
Apexi power fc programmable ecu with hand held remote display
AVC-R electronic boost controller
Std 200sx gearbox
ACT superlight billet steel flywheel
Exedy uprated organic clutch
Custom made dunning and fairbank propshaft
Bosch 044 motorsport fuel pump
Pace products caterham 4 core racing alloy radiator
Adjustable Fuel pressure regulator
Swirl tank
Running gear
4.1 ford sierra 7.5 Tran-x plated 2way diff
Front uprights are sierra 2wd but have been fitted with the calipers and discs from the xr4x4, the calipers have a larger diameter piston and
therefore giving you more stopping power.
Hubs have been redrilled for extra lock
Rear disc brakes from an xr4x4
Hydraulic handbrake
2.9 ratio rack fitted
Gaz adjustable coilovers
Wheels
205 50 15 Colway cut slicks (road legal)
15x8 XXR 002 wheels
4x108-4x100 PCD adapters (28mm)
Interior
2 fibreglass bucket seats
3" harnesses
Fuel switch
Battery cut off
Plumbed in fire extinguisher
VDO cockpit vision electric speedo driven from the pick up sensor inside the gearbox, with matching rev counter, water temp, fuel and oil pressure
Stack boost gauge
Bright 6 warning lights
Carbon dash
Full rollcage
Leather dished steering wheel
[/SIZE][SIZE=2]And lots more I cant remember at the moment!
Located between Bristol and Bath, can be delivered anywhere for a cost
I do not need to sell the car, it has cost a serious amount of time to build it and cost a massive amount. The car is ridiculously quick so no test
drives without fully comprehensive insurance that covers my car. Insurance is VERY cheap on these cars.
More pictures to come
£9500
Just added a new HKS actuator, now comes on boost super fast!
Possibly open to a PX
