With the change from Type 9 to Cossie T5 this is no longer required so here it is, complete kit ready to bolt on including a couple of spare plastic
u-clips that always seem to wear out. You will probably want to strip and clean it but other than its ready to fit.
£20 inc P&P
Does this make the throw/angle shorter or is it just a shorter shaft?
Sold
Itas a shorter shaft but the pivot point gets moved as well giving a shorter throw.
