New hand brake handle, lotus 7 badge, universal fit, alloy and leather look £5 + £2.50 postaged SOLD TO SNAPPER
[img]
[/img]
Mirror used to pass sva, complete with fixings £5 INCLUDING POSTAGE UK
SOLD TO GAVMAX
[img]
[/img]
Switch 3way £2 posted UK
[img]
[/img]
ILUMINATED GREEN INDICATOR SWITCH NEW PAID £18 FOR THIS £5 posted uk
SOLD TO ROB
[img]
[/img]
Radom selection of cable ends and yokes and pins and 1.5m of lined cable inner and outer, good quality "not cheap bike cable", suitable for
throttle or clutch cable.
£5 + £2 uk postaged NOW SOLD
[img]
[/img]
3 MIKALOR EXHAUST/HOSE CLAMPS, 2X 63MM TO 68MM DIAMETER ONE NEW AND ONE USED, AND ONE47MM TO 51MM AS NEW.
£5 POSTED UK FOR ALL 3
SOLD TO GAV MAX
[img]
[/img]
3 position gearchange arm, as supplied by MK,USED, just requires painting, allows you to ajust for a short change or long change throw on your gear
linkage.
£3 posted uk NOW SOLD
[img]
[/img]
silicon hose 63/64mm inside diameter, 75mm long.
£3 posted uk
[img]
[/img]
Pair of Wipac indicator housings, E marked for sva, in as new condition, "note no bulb holders or bulbs will be supplied with these, handy for
replacing cracked ones, I think bulb holders are available on ebay . they are about 10cm diameter with around 75mm hole centres standard fit.
£5 posted UK
[img]
[/img]
Exhaust webbing 1.3 metres long, 50mm wide.
£3 POSTED UK
[img]
[/img]
Just to add if anyone wants to collect they can do, and I will knock off £2 per item
And if anyone wants a few items, I will do reduced postage costs
Cable ends etc sold to "Jenko" cheers Paul
Gearchange arm sold to "flick" cheers Paul
Handbrake thingy pls
Hi
Could I have the Micalor exhaust clamps please
Gavin
Just the lights, webbing, 3 way switch and silcon hose left now
EVERTHING NOW SOLD Thankyou everyone
