type 9 gearbox mount used but in good condition £15 delivered
Selection of samco silicon hoses 1 x 38 to 32mm, 1 x 38 to 38mm, two corners 38 to 38 mm as new never used £15 delivered
sold
Cortina haynes worshop manual - £10 delivered?
alternator quinton hazell standard alternator used many ford engine £20 delivered
indicator stalk with green flashing light as new never used £10 delivered
sold
fog light switch with light indicator £4 delivered
mx5 in tank fuel pump, level and filter complete- ideal all in one unit £20 delivered
need to clear garage. parts are in bedfordshire
please email
[Edited on 31/12/13 by striker1660]
Hi there.
I'll take the indicator stalk please.
Thanks,
Matt
Spooky... Looks like the Subaru In tank fuel pump is the same as an mx5 one... You learn something new every day :-)
Dave B
Dave, you maybe right I got this as part of a project. i assumed as he has the mx5 engine it was from the same car. So your likley to be correct in that it's a suburu pump. Thanks.
The pump be ok to use with a pinto engine ?
I have mine running 3 bar on a fuel injected Zetec... It us a bit noisy but works a treat... I don't think the Pinto will be fuel injected so you
do need to check with those more knowledgeable than me....
Dave B
if the engine is injected it's fine.If it's carb afraid not.
u2u hoses
hoses and indicator stalk sold
asny more takers for the outstanding items?
