FS: Metal lathe
Benzine - 14/6/14 at 01:31 PM
I don't know what brand this is as there are no markings that I know of. I bought it from an old gent from the next street in the village a few years back. I'd imagine from the design that it's quite old. I've been using it for taking out lips from brake shoes, turned a gearknob, modified pulleys, lots of basic jobs like that. In the pic below you can see a 60cm rule to the right hand side as a size reference. Between chuck and tailstock is around 75cm, there's a hole through the chuck for longer bars. There are about a dozen misc cutting bits, most look to be home made and all could do with sharpening (or getting a set of new bits) It has some thread cutting gears included, and the thread cutting part engages - I've never needed to use it though. The on/off switch is old, it works but there's a knack to using it.
The stand unbolts from the main bed, and the motors mount unbolts from the bed (I made this mount - the previous owner used a brick ledge in his outbuilding to mount the motor to but as I rent I didn't want to drill/modify the walls!)
Thread cutting gears + larger chuck
Center of the chuck to the bed is approx 5 1/4", but as you can see in this pic there's a section that can be unbolted to give an extra inch
Could be picked up with an estate with the seats down (that said, I could fit it all in a '97 vw polo with seats down, was just a bit awkward)
£100
Any questions just ask and I'll try to answer asap
[Edited on 14-6-2014 by Benzine]
DIY Si - 14/6/14 at 03:16 PM
If you can wait until I'm less busy in two weeks time, I'll have that!
AntonUK - 14/6/14 at 04:26 PM
very temped, and i'm in leicester this week too... oooh decisions...
what is the length overall, would need to check that it fits in the garage
Benzine - 14/6/14 at 07:41 PM
Length is around 145cm. I'd rather sell to someone that can collect sooner than 2 weeks to be honest, got a hell of a lot of stuff to sell/sort/get rid of. If it's still here in 2 weeks though...
AntonUK - 15/6/14 at 09:51 AM
I'll pop into the garage in a bit and check dim's
AntonUK - 15/6/14 at 12:21 PM
u2u sent
Benzine - 15/6/14 at 08:12 PM
Now sold
